wow what an awesome thing
unforgettably at that price its a colossul waste of money
CPU: AMD FX-8350 - Noctua NH-D14 | Asus Crosshair V Formula | 16GB Kingston HyperX | Plextor M5P Extreme 256GB SSD
GPU - Asus AMD Radeon 6950 Direct CU II 2GB |
Seasonic 1000 W Platinum | Cooler Master 690 ii Advanced | Asus VE248H + VE248Q
https://linustechtips.com/topic/5728-1tb-usb-flash-drive/#findComment-64220
Why the H would you need to have 500+gb on a USB key?
The only thing I use USB sticks for is installing OS's...
you can use when you want to share your library with someone. Better than carrying an external drive and risking damaging it..
I don't see any other way to use this.
https://linustechtips.com/topic/5728-1tb-usb-flash-drive/#findComment-64785
