GTX 760 Higher temps.
Go to solution Solved by Rolling Potatoe,
1 minute ago, Muyke said:
Well, however.. When should I start worrying about my temps? I know 75C is fine but when it's alert status ? :)
I had a 570 once that i just let run at 90 °C so its more quiet :D.
90-95°C is about where the limit is, usually running a card @ 85°C is very safe and reasonable for some quiet gaming, its about where id aim with the fan curve for a new card.
Hello guys,
I have GTX 760 4GB Asus Striker Platinum RoG GPU and I'm just curious about one thing.
First of all , when I bought this card iddle temps were 20-25C and on heavy load max 65C. It was awesome...
But now, card is old about 2 years and it's running hotter then before. System setup is the same, same case , same fan setup, gpu fans on "auto", same ambient temp (about 25c).
Now , my card is running on 30-35C iddle, 75C on heavy load. I also replaced thermal paste 2 days ago and blew all the dust from the gpu cooler itself (thermal paste is CM: IC Value V1.) and it's not running like before when it was brand new.
Is that normal for GPUs to get hotter from time to time or it should perfom just like when they were brand new ?
Thanks.
https://linustechtips.com/topic/572614-gtx-760-higher-temps/
10 minutes ago, DominicNikon said:
did you dust it? as in is their dust on the GTX 760?
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/572614-gtx-760-higher-temps/#findComment-7503422
Mhh, maybe your room is just warmer or the fan curve was changed, also if you properly cleaned and replaced the card the airflow in your pc case just might be worse (e.g. if your intake dust filter is full or your cables are a mess.).
It might also be that you remember it incorrectly (took the gpu temp too early or with the side panel off etc.)
Anyways, 75°C doesnt really hurt your gpu, so its fine.
https://linustechtips.com/topic/572614-gtx-760-higher-temps/#findComment-7503433
Agreed, with my cards default fan curve it runs at 82C under load but with a custom fan curve it runs at 67-70C.
https://linustechtips.com/topic/572614-gtx-760-higher-temps/#findComment-7503450
https://linustechtips.com/topic/572614-gtx-760-higher-temps/#findComment-7503485
https://linustechtips.com/topic/572614-gtx-760-higher-temps/#findComment-7503503
Thanks for replys. :)
Cheers
https://linustechtips.com/topic/572614-gtx-760-higher-temps/#findComment-7503529
