13 hours ago, Berchim said:
Gtx 970 g1
corsair rm750m
h100i gtx
msi x99a sli plus
sanddisk extreme pro ssd 480gb main boot drive
some Western digital 2tb storing drive
i7 5820k
once there was a green screen
once a blue
rest was black
then sometimes there would be like a noise like grrrrrrrrrrrrrrrr
What kind of RAM do you have?  How is it plugged into your board?
I had a similar problem years ago with another computer i built.
corsair vegeance lpx 16gb first and eight slot like it said in my mobo manual
Sorry for my late response.
Did you get it worked out yet?  I have the same board as you and i recommend reinserting the ram sticks.  I dont know wtf they were thinking with their ram slot design, in that only one end of the ram slot has the lock in push tabs.  I had a situation where the ram wouldnt insert properly on the non push tab end.  This caused the ram to be "sometimes detected" by the pc.  Maybe in your case, you have the ram sticks pushed in a little better but not completely, so that when your motherboard heats up, the slot flexes and then loses contact with the ram module.
Try reinserting your ram.  As you put it in, push with equal force on both sides until the topside makes contact with the lock in push tab.  Then push and make sure the non push tab end is all the way in before pushing the lock in tab end in.
