I am currently using my ixfinity modem which is attached with a cable ( The round screw in one), and i need to upgrade it because it is old and becoming slow. So i need help on what i should buy the main thing is the difference between modems and wireless routers. I need a modem to connect to the cable but i dont know what ones support wireless and which ones dont. Or if they all do and i dont need a router. Any information would be helpful Thanks.
https://linustechtips.com/topic/572193-wifiinternet-help/
