Hy. So i can put together 2 build. I already have PSU CM V750W and MBO MSI Z170A Krait Gaming. I can either get build with better MBO 'cus this one doesn't have a lot of good reviews but sacrifice CPU power or get better CPU with this MBO. what do you suggest?
http://pcpartpicker.com/p/NLbJvK
or
http://pcpartpicker.com/p/Ksjzbv
WHITE MIST
CPU: I7 6700K @ 4,7GHz 1,38V GPU: ASUS GeForce GTX 980 Strix @ 1568MHz RAM: G.Skill TridentZ 4x8GB 3200MHz CL16 MBO: MSI Krait gaming 3X Z170 PSU: Cooler Master VSM 750W CASE: Fractal Design Define S/window CPU COOLER: NZXT Kraken X61 STORAGE: Samsung 850 EVO 250GB & 1,5TB Seagate Barracuda
PcPartPicker - White Mist
Vidox Production - Official page
https://linustechtips.com/topic/571908-build-from-bottom-or-not/
i would go for the i7,
motherboards nowadays are pretty much the same
its just the aesthetics, so if you like the maximus board, you can get it
if the computer is purely for gaming purpose, an i5 will do just fine anyway
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/571908-build-from-bottom-or-not/#findComment-7496620
think that this MBO will do okay OC to 4.6GHz
and yes, the PC is only for gaming..
WHITE MIST
https://linustechtips.com/topic/571908-build-from-bottom-or-not/#findComment-7496634
overclocking nowadays are mostly chip limited than motherboard limited tbh
unless you're going LN2 of course lol
well purely gaming, an i5 will do fine, but its always better to get a higher performing chip if you can :D
https://linustechtips.com/topic/571908-build-from-bottom-or-not/#findComment-7496639
as you see, i can get both of them haha but idk about this MBO. if i go with maximus hero it's a bit more expensive.. but would like to have good looking PC but also performance haha
WHITE MIST
https://linustechtips.com/topic/571908-build-from-bottom-or-not/#findComment-7496646
as i mentioned, motherboard nowadays isnt really going to affect performance much
unless you take a $50 board and compare it to a $300 board lol
the MSI krait is a decent board and will do just fine :D
https://linustechtips.com/topic/571908-build-from-bottom-or-not/#findComment-7496670
