1 minute ago, Eponymous98 said:
Resulting in higher temperatures though, I suppose...
well yea, but if you can do push pull, you should since it allows lower rpm to perform the same as one fan with high rpm
thus achieving silence :D
and you have the option to crank up the speed if you're really into performance
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/571904-cpu-liquid-cooler/#findComment-7496628
dBa adds up 4 fans instead of 2. lol
https://linustechtips.com/topic/571904-cpu-liquid-cooler/#findComment-7496649
My budget is not that high anyway...
No worries mate, there are plenty of other options. If not the predator then maybe one of these three: 280mm http://www.corsair.com/en/hydro-series-h115i-280mm-extreme-performance-liquid-cpu-cooler or 280mm (different design) http://www.corsair.com/en/hydro-series-h110i-280mm-extreme-performance-liquid-cpu-cooler or 240mm (new name) http://www.corsair.com/en/hydro-series-h100i-v2-extreme-performance-liquid-cpu-cooler .
https://linustechtips.com/topic/571904-cpu-liquid-cooler/#findComment-7496658
1) noise is measured on a logarithmic scale, 20db + 20db =/= 40db
2) fan noise increases exponentially as the speed increases
https://linustechtips.com/topic/571904-cpu-liquid-cooler/#findComment-7496661
2 minutes ago, Loleo said:
The first one looks like a nice option. Which is better though, this or the Kraken X61?
https://linustechtips.com/topic/571904-cpu-liquid-cooler/#findComment-7496673
Mhmm... too late for me too browse around for more reviews but look here: https://www.guru3d.com . Search for a cooler then go to the  review and then finally look at the comparison graphs. If they are similar look at the guarantees, looks and customer reviews and service. Good luck and have a good one.
https://linustechtips.com/topic/571904-cpu-liquid-cooler/#findComment-7496689
Will do, thanks a lot :D
https://linustechtips.com/topic/571904-cpu-liquid-cooler/#findComment-7496914
