My friend recently built a new rig with an Asus Z170-A motherboard, 980ti and 6700k. However the motherboard back panel doesn't seem to be outputting anything. No HDMI signal (GPU too), no USB power (keyboard won't light up). All the component lights up however so I really don't know what's wrong. The motherboard doesn't seem to have a speaker included or an error code display.
Anybody got any ideas?
Things we've tried:
Clearing CMOS, only using 1 stick of ram, different power source and trying both the motherboard and graphics card HDMI output.
Please quote if you want a person to reply, they won't get a notification otherwise.
PC Specs
(CPU: Intel 4790k) (GPU: Gigabyte GTX 970 WF3OC) (Mobo: Asus MAXIMUS VII RANGER) (RAM: Red Corsair Vengeance Pro 2*8GB 1600MHz) (HDD: WD Green 2TB) (SSD: Samsung 840 Evo 120GB) (CPU Cooler: Cooler Master Hyper 212X) (PSU: Corsair RM750) (Case & Fans: Corsair Obsidian 450D) (Monitor: Asus VX239H)
https://linustechtips.com/topic/571902-cant-post-mobo-no-output/
try only booting with cpu, 1 stick of ram and the necessary connections (24pin and 8 pin) from the psu
and connect only your monitor, no other peripherals
short the power button pins to turn on, wait around 2 minutes and see if it posts
if it doesnt, its either bad cpu, ram, motherboard or psu
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/571902-cant-post-mobo-no-output/#findComment-7496565
Yeah, tried all that. The problem is my friend has no extra parts to try which one is broken. Pretty sure it is motherboard tho? It lights up but doesn't output USB power. A bad CPU wouldn't do that right?
EDIT: I watched one of Linus' old 50 minute build guides and it looks like he got the cables right.
PC Specs
https://linustechtips.com/topic/571902-cant-post-mobo-no-output/#findComment-7496696
it depends, might be the psu too, might be the motherboard
its best if you can just bring it into a shop and have them check it if you dont have spare parts
or just buy the parts lol
https://linustechtips.com/topic/571902-cant-post-mobo-no-output/#findComment-7496704
1 minute ago, Moonzy said:
-snip-
That's an expensive way to figure out the problem. I'll probably just ask him to refund a new board.
PC Specs
https://linustechtips.com/topic/571902-cant-post-mobo-no-output/#findComment-7496716
-bump-
PC Specs
https://linustechtips.com/topic/571902-cant-post-mobo-no-output/#findComment-7496777
