I've had a gaming PC from when I worked at Activision for a while. I've steadily upgraded it over time. But now I'm getting ready to build my own computer. I've done some research and I think all these parts are compatible but would like some help from those who are more experienced than I am. I have a few questions. Are these parts compatible? Will my PSU have enough Watts? Am I missing anything crucial?
Case: In Win 703
http://www.amazon.com/Development-Retail-Chassis-703-black/dp/B00SETR1NI/ref=sr_1_1?ie=UTF8&qid=1458953659&sr=8-1&keywords=In+Win+703
PSU: Thermaltake TR2 500w ATX12V v2.3:
http://www.amazon.com/Thermaltake-Watts-ATX12V-CrossFire-Supply/dp/B0058FAYQC/ref=sr_1_1?s=pc&ie=UTF8&qid=1458954476&sr=1-1&keywords=Thermaltake+TR2+500W
Mobo: ASUS RGB LGA 1151
http://www.amazon.com/dp/B0189T70YC/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3N24F2PH1VLQN&coliid=I1919ZD2KWBC2J
CPU: Intel Core I7-6700K
http://www.amazon.com/dp/B012M8LXQW/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3N24F2PH1VLQN&coliid=I3BKZR85JMBVZ9&psc=1
GPU: MSI GTX 970
http://www.amazon.com/MSI-GTX-970-GAMING-4G/dp/B00NN0GEXQ/ref=sr_1_1?s=pc&ie=UTF8&qid=1458953989&sr=1-1&keywords=msi+gtx+970
RAM: Corsair Vengeance 2400 MHz C14 (Link comes with 2 to equal 16GB but I might get two of them for 4 to equal 32GB)
http://www.amazon.com/dp/B0123ZC250/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=3N24F2PH1VLQN&coliid=I1CN3JNQEI3IXW
Boot SSD: Samsung 85 EVO 120GB
http://www.amazon.com/dp/B00OAJ5N6I/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=3N24F2PH1VLQN&coliid=I2S69F8N053LG2&psc=1
Secondary SSD: Samsung 85 EVO 500GB
http://www.amazon.com/dp/B00OBRE5UE/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3N24F2PH1VLQN&coliid=I2KSN518A07BLV&psc=1
Fans: Corsair Air Series AF120 LED Quiet Edition
http://www.amazon.com/dp/B00F6S0XJO/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=LPGAYCXWYPYR&coliid=I32WHMESS8YHUB&psc=1
https://linustechtips.com/topic/571628-computer-building-help/
use pcpartpicker, its an amazing website, has compatability options and everything, also a psu wattage thingy, but to answer your question, id go for a 650w -750w PSU, 500w might be able to work but it'll be cutting it close, you want room for expandability
https://linustechtips.com/topic/571628-computer-building-help/#findComment-7494371
Case: In Win 703
GPU: MSI GTX 970
also, I recommend going for a gtx 980 or 980ti if you have the money, 970 is fine but if you're going with a new skylake cpu, you might aswell go for a higher end gpu
https://linustechtips.com/topic/571628-computer-building-help/#findComment-7494375
I have an 970 in my system now. I do intend to upgrade to a 980 TI eventually though. The ultimate goal is to SLI two of them. Right now, this is what I own and what I have the money for.
https://linustechtips.com/topic/571628-computer-building-help/#findComment-7494387
fair 'nuff, I understand budget, I had to make a gaming rig with $350 :P
https://linustechtips.com/topic/571628-computer-building-help/#findComment-7494389
Majority of the build is good but the PSU is crap. Thermaltake's TR2 series are something you want to stay well away from.
I recommend a 500W PSU from either SeaSonic or XFX. Or the EVGA SuperNOVA 550 G2 for the best quality possible at a fair price.
Also, you want a Z170 motherboard to overclock your unlocked K-series CPU (with a decent aftermarket cooler) and your RAM. The B150 cannot do either.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/571628-computer-building-help/#findComment-7494438
Case: In Win 703
GPU: MSI GTX 970
Not quite related to your topic, but what was it that you did at activision
https://linustechtips.com/topic/571628-computer-building-help/#findComment-7494471
I worked as a QA Tester hired through Volt. A few months ago, they were having a "yard sale" at our studio and giving away some of the old gaming computers.
https://linustechtips.com/topic/571628-computer-building-help/#findComment-7494478
