  I recently built a new computer which will be used primarily to create 3d animations and for rendering.
  My PC consists of a:
xeon e5-2676 v3 (ES) according to CPUID
msi x99a xpower motherboard
32gb corsair vengeance lpx 2133
Cooler Master hyper 212 evo
nvidia GeForce 8600 GT ( will be upgrading this to a quadro m6000).
samsung 850 evo 256gb ssd
segate  3tb hdd
My question is this. Linus has a video where he gives a Xeon a slight overclock by increasing the BCLK. He also demonstrates that the multiplier can't be changed. However I was able to change the multiplier to my CPU from auto to x27 and CPUID recognizes that my CPU went from a 2.4 MHz to 2.7 MHz. Does that mean my multiplier is unlocked? Should I try changing other settings to get more performance? Temps are sitting around 70c at 2.7 MHz on aida64 stability test.
https://linustechtips.com/topic/571556-overclocking-xeon-advice/
Does the multiplier go any higher than 27 ? Officially , the 2676v3 isn't in intel's database and was never released, so i can't tell you how far it boosts . It may be that you are forcing it to boost on all cores .
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/571556-overclocking-xeon-advice/#findComment-7493634
Thanks for the reply back Coaxialgamer. I tried changing the multiplier to x29 and it saved it in the bios but cpuid says that it's on a multiplier of 27 even though the bios says differently. The cpu specifications in bios tells me that the cpu ratio is unlocked but x27 is the most all 12 cores will get. Aida64 report confirms this.
Max Turbo Boost Multipliers   1C: 30x, 2C: 29x, 3C: 28x, 4C: 27x, 5C: 27x, 6C: 27x, 7C: 27x, 8C: 27x, 9C: 27x, 10C: 27x, 11C: 27x, 12C: 27x
--------[ Overclock ]---------------------------------------------------------------------------------------------------
    CPU Properties:
      CPU Type                                          12-Core Intel Xeon E5-2676 v3
      CPU Alias                                         Haswell-EP
      CPU Stepping                                      B0/L0
      Engineering Sample                                Yes
      CPUID CPU Name                                    Genuine Intel(R) CPU @ 2.40GHz
      CPUID Revision                                    000306F1h
      CPU VID                                           1.1134 V
    CPU Speed:
      CPU Clock                                         2836.3 MHz  (original: 2400 MHz, overclock: 18%)
      CPU Multiplier                                    27x
      CPU FSB                                           105.0 MHz  (original: 100 MHz, overclock: 5%)
      North Bridge Clock                                2731.3 MHz
      Memory Bus                                        1120.5 MHz
      DRAM:FSB Ratio                                    32:3
    CPU Cache:
      L1 Code Cache                                     32 KB per core
      L1 Data Cache                                     32 KB per core
      L2 Cache                                          256 KB per core  (On-Die, ECC, Full-Speed)
      L3 Cache                                          30 MB  (On-Die, ECC, Full-Speed)
 I ended up setting the CPU ratio to auto and increasing my BCLK to 105.4 which gave me 2.8MHz. I stressed tested it for about 12 min and CPU temp was steady at 80c and
 my memory went from 2133 to 2400. I don't know if I should increase the BCLK more, the TjMax Temp on the CPU cores is 103c. Also, I'm wondering if the temps I'm getting
are normal  for the type of air cooler I have. I didn't have that much thermal grease to begin with, but I dont know if adding more would help get better temps. I guess I would
just have to test it out to see if it improves.
https://linustechtips.com/topic/571556-overclocking-xeon-advice/#findComment-7494608
