Wasn't sure what section to post so chose this one.... so I was thinking of going for a Dark Rock pro 2 from Be quiet! or a Corsair H80i. Which one will give me best performance and sound? Fitting these on a i5 4670k and in a Fractal design Define R4 case.
https://linustechtips.com/topic/57079-watercool-or-air-cooling/
Go for the air cooler unless you want a 240mm + configuration.
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772487
I say skip the Dark Rock Pro 2 and go for a Noctua NH-D14.
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772491
air cooler, it has better performance. and the dark rock is sexy looking, make sure it fits tho'
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772495
Dark Rock Pro 2
Air Cooler>120MM liquid cooling
What about a h100i vs dark rock pro 2?
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772524
H100i no doubt.
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772527
H100i, but if you're not in the US try and get the Swiftech H220.
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772532
Might as well get the Swiftech h220 if you're considering a h100i.
CPU: Ryzen 5 3600 @ Stock, CPU cooler: Dark Rock 4, Motherboard: MSI B450M PRO-M2 MAX, RAM: 2x8GB Crucial Ballistix DDR4 @ 3000Mhz, GPU: EVGA GTX 1080 ACX 3.0, SSD: Crucial P1 1TB M.2 + 2x120GB SSDs, Case: Corsair 110R, PSU: Corsair TX650M, OS: Windows 10 64-bit.
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772533
h100i, but the price difference is certainly there
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772535
H100i no doubt.
Alright well I will go with the h100i. The Swiftech H220 is way to high priced for me. So I won't make another thread on the fan setup so if you may allow me... I was planning to get 3 noctua FLX and remove the fans that came with the R4. Now should I put my H100i as a front intake or top exhaust? And what fans do you guys consider me using.
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772557
Rosewill Hyperborea.
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772565
top exhaust, and i suggest scythe glidestream, for they are quieter and higher CFM than Noctuas(according to tweakers.net)
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772566
Top exhaust, Corsair SP120's.
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772602
Ok, but if I want noctuas which ones would I need?
Don't they come with the cooler? Or the ones on the cooler are like a lower end version.
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772619
NF F12's, although I dont like the color of em.
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772638
Yeah... but if I mount my rad, can I make that the fans are closest to the exhaust? Or I need the fans closest to the MOBO?
you want the fans closest to your exhaust, in a pull configuration, so you can easily clean your rad if nessisary.
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772657
Yes, I believe so. make sure to get other peoples opinion too btw, More people know more.
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772663
yes, without the ram fan, unnessiary things..,
https://linustechtips.com/topic/57079-watercool-or-air-cooling/#findComment-772709
