VDSL cable?
Solved by SaladFingers,
11 minutes ago, xAssassin124x said:I need to get a new DSL cable for my BT Modem but on the modem it says it is VDSL. Does that mean I need a VDSL cable or can I just buy an ADSL cable?
There aren't any ADSL/VDSL cables
Are you talking about the cable that comes from the wall to your Router or for the cable that leaves the Router and goes to the PC? First is probably a regular telephone cable (since this is VDSL) and the other is an Ethernet cable.
