PC does not power on properly
On 24/03/2016 at 9:37 PM, VaynardX said:You have a good PSU but like all others have said, it could mean that the PSU is faulty. Anything related to booting problems almost always relates to either the PSU or the RAM.
On 24/03/2016 at 7:19 PM, Nex Cube said:If I had to guess though, I would say your PSU is probably going bad.
On 24/03/2016 at 3:33 AM, SaladFingers said:
You are right about holding the power button with the computer unplugged, that's why it's done. It is weird though that this doesn't actually get it running but leaving it off for hours will. Is it running normally when it finally boots? To this point I actually don't think it has anything to do with RAM.
It could very well be a faulty capacitor on the PSU. The strangest things can happen when capacitors are starting to go bad. Do try that other PSU to see if it works, and if so, get an RMA process going for your own (it probably still is under warranty).
On 25/03/2016 at 0:13 PM, 0x1e said:Sounds like a safety feature is tripping.
The steps you are taking are normally the ones used to reset a PSU, however it shouldn't take hours. Minutes at most.
That would lead me to think your PSU is faulty. Either it was poorly built (does happen from time to time) or something has fried the PSU, like a power surge.
Try the different PSU and see what happens. I would assume it will work perfectly fine.
Well, I tried the PSU on loan from a friend. My PC powered on as it should each and every time I pressed the case's power switch. So, I guess its time to RMA my Cooler Master PSU. Thanks all for the assist. ![]()
