I am building a budget gaming pc with this gpu (gtx 950 2gb) http://www.newegg.ca/Product/Product.aspx?Item=9SIA92G3UY1893&cm_re=msi_geforce_gtx_950_oc-_-14-127-919-_-Product
What cpu do you guys recommend? My budget for it would be anything around $150 CAD and lower. I will be playing games like H1Z1, CS:GO and Skyrim.
Thanks!
https://linustechtips.com/topic/570488-budget-build-cpu-help/
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/570488-budget-build-cpu-help/#findComment-7483593
The Pentium G4400 is very good
you have been visited by ascii stephen harper the pc builder
nothing bad will happen to you unless if you post "ignfdofsginedsoignoifdn" in this thread
why? because you'll be banned for spam
lol
https://linustechtips.com/topic/570488-budget-build-cpu-help/#findComment-7483598
