I have a buddy that asked me to make him a computer an all he cares about is movies he wants to be able to download store and burn dvds without waiting a long time for them to burn im not very sure out side of getting a better burner how u increase read write speed to a dvd,
budget $ 500 -750
Aim $ burning cds and dvds
monitors none needed
Peripherals none needed
Why are you upgrading? simply to have a new storage and burning medium for dvd movies he has over 250 dvds
any cases are fine he doesn't care as long as its functional
thanks in advance for your help
https://linustechtips.com/topic/570089-build-for-co-worker/
Indeed the CD/DVD/BLUERAY burner is the slower part of the build, you cant possibly get a magic burner that does it instantl, just grab a good one from whoever.
Planning on trying StarCitizen (Highly recommended)? STAR-NR5P-CJFR is my referal link
https://linustechtips.com/topic/570089-build-for-co-worker/#findComment-7479557
Hes probably looking for something linus does, puts the dvds on a server for him to watch and enjoy later. Thats going to take you a few days worth of hours to do though....
No the power does not matter, what you are looking for is just a fast blue ray reader and burner, or DVD. Just make sure he has Several TB of HDD space ready
https://linustechtips.com/topic/570089-build-for-co-worker/#findComment-7479640
