i would think it should be fine, i mean i will assume ur watch is on ur wrist so it wont go below 32F guaranteed. Phone in your pocket? Also not going below 32F soooo your fine
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/569988-will-it-work/#findComment-7478654
If you have your phone in your pocket and the watch on your wrist, when it gets cold enough for those to stop working, you'll have bigger problems than these devices not working.
You should be fine as long as you don't leave it outside. Even then, the shutdown is only temporary, it should start working again when you warm it up (watch out for condensation!). Only thing that has the potential to permanently stop working is the battery. It's unlikely and even if it happens, it's not that expensive to replace it.
https://linustechtips.com/topic/569988-will-it-work/#findComment-7478764
  • 2 weeks later...
yeah...I was wondering for vacation to montana, but thanks! my battery stayed around 40F on my phone and I didn't want to take the risk with my watch because its pretty new (to me).  Everything did work as good as the 80F weather I live in
https://linustechtips.com/topic/569988-will-it-work/#findComment-7522565
