Fan Controller That has 0%
A lot of them do but depends on the kind ur looking for, slider controllers give a range of power while electronic ones might let u go to 0% many have no middle ground from 0%-40% since most fans won't start spinning at such a lower power setting. Do a little bit of research to make sure the fan controller you're getting will achieve 0%. Hope that was helpful (:
https://linustechtips.com/topic/5695-fan-controller-that-has-0/#findComment-63947
