Hi, I recently upgraded to windows 10, and with it, came a new volume bar (yay...).
So my situation is I have a HP TouchSmart 320 pc (don't judge) with integrated Beats audio (don't judge) which came with its own Beats volume bar. After a while it stopped working, and every time I changed the volume the bar would show as white, unclickable, without any texture on it. Volume worked but I had no way of knowing at what level of volume it was (the bar I'm talking about is the one that pops in the middle of the screen whenever you change the volume). But it was still working, and to this day if I click over where it is supposed to appear it will show as the front window (this is very irritating when playing full screen games). So I installed a default volume indicator from HP which showed me the actual volume level, while the white rectangle that used to be the beats audio bar was still showing, so I had 2 (quite big) volume bars appearing every time I changed the volume.
Windows 10 came, and with it the small uninstrusive volume bar at the top left corner which I like, but that also meant that now I have 3 volume indicators whenever I change the volume.
Is there any way to get rid of the volume bars from beats and the one I downloaded from HP? Thanks.
https://linustechtips.com/topic/568719-need-help-uninstalling-volume-bars/
Did you check your programs list? You should be able to uninstall them from there.
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
4 minutes ago, Allshevski said:
Clean Install FTW, seriously, will take 30 minutes and get rid of all manufacturer crap. It doesn't look like you have too much stuff to back up..
Believe me I have a lot of programming, and statsitcal programs. Plus 30+ games installed. I'm afraid a clean install will make me download and install of them again, which will take me at least a week
Oh well.. Do you have any other HP related software on your PC? The worst thing is that it could hide anywhere..
I need S340. But more Define S'ish
