This is over budget but 9000 series will make prices drop and I assume you will have some more money by the end of the month. http://pcpartpicker.com/p/1Ee5f
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/56832-help-with-my-build/#findComment-768276
Case-NZXT H440 | Motherboard-Gigabyte Z77X-UD3H | RAM-Kingston HyperX Blue 2x8GB 1600MHz | CPU-Intel 3770K @ 4.3GHz at 1.215v | Heatsink-Coolermaster Hyper212 Evo | GPU-EVGA GTX660 SC | SSD-MX200 250GB | HDD-Seagate Barracuda 3TB | PSU-EVGA GS650
Mouse-Logitech G600 | Keyboard-Ducky Shine 3 MX Blue. white backlight | Headphones-Audiotechnica ATH-M50s. Beyerdynamic DT990
https://linustechtips.com/topic/56832-help-with-my-build/#findComment-768360
This is a little over budget but I managed to fit in an ssd and an aftermarket cooler PCPartPicker part list
| 3570k @ 4.4.ghz | Hyper 212 evo | 8GB (2x4GB) 1600mhz Corsair Vengeance | Gigabyte Z77X UD3H | Corsair CX750M | Corsair 300R | OCZ 240GB SSD | Seagate 1TB 7200rpm HDD | Asus DCUII 7950 @1150mhz core 1600mhz mem
| BenQ XL2411T | Corsair Vengeance K60 | Logitech G700 | steelseries Qck+ | Fiio E10 | Zalman clip on mic | HD 598 | ATH-M50 |
https://linustechtips.com/topic/56832-help-with-my-build/#findComment-768373
Including a monitor? http://pcpartpicker.com/
You know you can't just copy and paste the link you need to use bb code
https://linustechtips.com/topic/56832-help-with-my-build/#findComment-768408
My intention was to give him the site, not a build.
ah right it was your comment before the link that made me think you intended to link a build with a monitor :P
https://linustechtips.com/topic/56832-help-with-my-build/#findComment-768436
A monitor counts as a peripheral.
I already have a monitor, keyboard and mouse
Do you need a copy of Windows? Also, do you mean $800 USD or what?
Fyi, you need to quote a post or tage a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/56832-help-with-my-build/#findComment-768517
