Hey guys, today I upgraded my 4790k up to a 6700k. The only hardware I changed was the CPU, Mobo and Ram. At idle I sit at roughly 30 however I get seemingly random temp spikes. According to the graphs in Intel Extreme Tuning Utility, this temp spike is not matching up with CPU voltage or utilization. This spike goes from around 30 up to 45ish.
Another instance I'd like to add is that opening up Skype while idle brings the temperature up to 60 degrees, but only for a split second, just long enough for the fans to spin up.
Intel XTU benchmark and stress tests run normal, as well as The Division on max settings. Temp does not reach over ~65 degrees.
Hardware:
Intel 6700k
Asus Z170-A
Corsair Plat (CMD16GX4M2B3200C16) 16g (2x8)
EVGA 980ti hybrid
Thermaltake 850w
Samsung 950pro m.2
Samsung 850evo
2x misc HDD
H110i GT (280) AIO
BIOS is updated to latest, drivers are installed. This was NOT a fresh Windows install, should I fresh install?
Cooler was reseated with new thermal paste. First application looked well spread and not overdone/not enough.
Anything I may be forgetting? I'll keep an eye out.
https://linustechtips.com/topic/567842-idle-temp-spikes/
Hardware:
try cleaning your cooler and reappling thermal paste otherwise try you might have to go a little bit extreme and try delidding
https://linustechtips.com/topic/567842-idle-temp-spikes/#findComment-7457469
Sorry, you beat me to it. I was updating my post because I accidentally posted before finished typing.
I have already reseated with new thermal paste, the first application looked perfectly normal as well.
https://linustechtips.com/topic/567842-idle-temp-spikes/#findComment-7457476
well if you have the extreme balls you could try delidding, in this video one of their chips had this sort of problem
, can you rma it tho?o.O
https://linustechtips.com/topic/567842-idle-temp-spikes/#findComment-7457485
I'm not quite sold that it's the chip. I'll wait for a bit and see if there are other responses. I'm familiar with delidding and will keep it in mind though for sure and will look into RMA.
https://linustechtips.com/topic/567842-idle-temp-spikes/#findComment-7457487
i wouldnt worry about it, as long as the temps are safe, i would monitor them periodically
https://linustechtips.com/topic/567842-idle-temp-spikes/#findComment-7457489
I believe that Intel CPU's are designed in a way where temperatures can spike up and down very rapidly as compared to something like AMD chips where they ramp up in temperature steadily. Maybe it's part of Intel Speedstep, where Skype somehow causes the processor to ramp up for a split second? As long as your peaking at 60s-70, you should be fine, that is a substantial amount less than the thermal throttling point on Skylake.
I like good humans and good food
https://linustechtips.com/topic/567842-idle-temp-spikes/#findComment-7457493
Hardware:
Intel 6700k
Asus Z170-A
EVGA 980ti hybrid
Thermaltake 850w
Samsung 950pro m.2
Samsung 850evo
2x misc HDD
is it the stock cooler and is the fan spining?
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
https://linustechtips.com/topic/567842-idle-temp-spikes/#findComment-7457517
Oops! H110i GT AIO. Pump is hooked up to CPU fan, rad fans are hooked to splitter that comes from the pump. Chassis fans are hooked up to their proper headers.
0-0 wow. Can u try and see if you can hear the pump working correctly you could have a failing pump.
https://linustechtips.com/topic/567842-idle-temp-spikes/#findComment-7457538
I don't hear any odd sounds. This pump has been in use with the 4790k and is only a few months old. In fact, it was working fine yesterday, and this morning. Under decent load gaming yesterday, not that that is unusual.
https://linustechtips.com/topic/567842-idle-temp-spikes/#findComment-7457543
huh... Is the voltage all good go in to the bios and do optmise load defaults. see if that helps.
https://linustechtips.com/topic/567842-idle-temp-spikes/#findComment-7457549
BIOS says 1.28, Intel XTU says 1.19-1.22 idle. XTU stress test says max voltage was 1.23. Only thing I have changed in the bios is boot order.
https://linustechtips.com/topic/567842-idle-temp-spikes/#findComment-7457567
you could have a bad cpu :(
https://linustechtips.com/topic/567842-idle-temp-spikes/#findComment-7457578
Those temps sound completely normal. All that really matters is max temperature achieved under load. Temp spikes to temps that are still in the safe zone are totally normal.
Core i5 6600k | Gigabyte GTX 970 Windforce | MSI Z170 Krait Gaming Crucial Ballistix Sport 16GB DDR4 2400 | NZXT S340 Red                                              EVGA SuperNOVA 750 G2 | Coolermaster Hyper 212 Evo | Razer Blackwidow Tournament | Logitech G600 Razer Kraken USB        If you want me to see your post, please remember to quote me!
https://linustechtips.com/topic/567842-idle-temp-spikes/#findComment-7457615
