Static mic noise, help?
Greetings,
So I used to have a Logitech G35, but I find it very uncomfy and have only used for voice chat. I use a Beyerdynamic DT770 Pro for audio/video and I am very happy with it.. Which is why I decided upons Linus' recommendation to buy a modmic 4.0.
Though after happily receving it, I have static noise using my integrated desktop MB mic input. My motherboard is an Asus VII Hero Z97 and I thought was supposed to have a good sound card.. At least it drives my headphones with a very good sound quality. Tried connecting it in the front panel as well, and keep it away from all other electric/signal cables to avoid interference.
Tried to connect my modmic to my laptop and all my static noise was gone, so it is clearly a grounding (GND) issue in my desktop, whether it is because of other components or what it may be, it is there.
VII Hero comes with Realteks software, and I can get rid of the static sound through the software, but end up sounding very metallic/robotic.. Not very natural sounding.
So, I am guessing a DAC is my only saviour? I could get another internal sound card, but I am predicting that it will only give me the same static noise.
Any suggestions what I can do to solve this?
Thanks in advance
https://linustechtips.com/topic/567704-static-mic-noise-help/
Make sure your system is connected to a grounded wall socket. If the hum is in the same frequency range as your AC power and if power plugs in your region are reversable, try plugging it into the wall the other way around.
daily driver
Intel Core i7-950 | ASUS SABERTOOTH X58 | 6x2GB Corsair XMS3 PC3-12800 | ASUS GTX970 STRIX | SB X-Fi Titanium
Samsung 840 EVO + WD Caviar Black | Fractal Define R3 | Phanteks/Noctua/NoiseBlocker cooling | Windows 10 Pro
MacBook Pro (13-inch Mid 2010)
Intel Core 2 Duo P8600 | Apple Mac-F222BEC8 | 2x4GB Samsung PC3-8500 | GeForce 320M
SanDisk SDSSDP | Apple A1278 Aluminium Unibody | macOS Sierra
Microsoft Lumia 950
Qualcomm Snapdragon 808 | 3GB RAM | Adreno 418 | Windows 10 Mobile
daily driver 2
Intel Core i5-750 | ASUS P7P55-M | 4x1GB Elpida PC3-8500 | Sapphire Radeon HD5870 | SB X-Fi Xtreme Music
Crucial M4 + WD AV-GP Green | Fractal Define R3 | Scythe/Gelid/Noctua/NoiseBlocker cooling | Windows 10 Pro
MacBook Pro (15-inch, Mid 2012)
Intel Core i7-3615QM | Apple Mac-4B7AC7E434945597E | 2x4GB Samsung PC3-12800 | GeForce GT650M
WD Blue | Apple A1286 Aluminium Unibody | macOS Sierra
server
AMD Athlon 64 LE-1620 | Jetway JNC62K | 2GB Corsair Value Select PC2-6400 | GeForce 8200 IGP
WD Caviar SE16 + AV-GP Green + 2x Red | Chenbro ES34069 | Scythe/Nexus/Noctua cooling | Windows Home Server
coming soon: Eve V
Intel Core i7-7Y75 | Skybay U3E1 | 2x8GB Samsung PC3LP-14900 | Intel HD 615
Intel 600P | Eve V Aluminium Unibody | Windows 10 Pro
https://linustechtips.com/topic/567704-static-mic-noise-help/#findComment-7456255
Thanks for your reply!
Yeah had a feeling that the AC power from the wall could be the issue.. Sadly I live in an older house without grounded sockets, so that is probably the reason.
Think that one of these could be my solution? http://www.roccat.org/en-US/Products/Gaming-Sound/Juke/ Or doesnt that filter the noise?
My G35 has zero static sound, which runs through USB.
https://linustechtips.com/topic/567704-static-mic-noise-help/#findComment-7456384
Power shoudlnt be a problem since its going through your power supply unit
The Dick of the audio page!
https://linustechtips.com/topic/567704-static-mic-noise-help/#findComment-7458791
