1 hour ago, xHadrian said:
Where do I get one of these custom loop water temperature sensors, y'know the ones with the LCD screen?
Also, how do they work?
Thanks.
I know xspc sells them so you can set it up to a plug. It comes in other colors:
http://www.amazon.com/XSPC-Sensor%C2%A0-Temperature-Display-Black/dp/B00FVVEF54/ref=sr_1_1/178-4963915-5732365?ie=UTF8&qid=1458304629&sr=8-1&keywords=xspc+temperature+sensor+plug
Tip to those that are new on LTT forum- quote a post so that the person you are quoting gets a notification, otherwise they'll have no idea that you did. You can also use a tag such as @Ryoutarou97 (replace my username with anyone's. You should get a dropdown after you type the "@")to send a notification, but quoting is preferable.
Feel free to PM me about absolutely anything be it tech, math, literature, etc. I'll try my best to help. I'm currently looking for a cheap used build for around $25 to set up as a home server if anyone is selling.
If you are a native speaker please use proper English if you can. Punctuation, capitalization, and spelling are as important to making your message readable as proper night theme formatting is.
My build is fully operational, but won't be posted until after I get a GPU in it and the case arted up.
https://linustechtips.com/topic/567442-water-sensor/#findComment-7453334
