This is a problem I had for some time: I use Command Center to control my CPU fan (Hyper212 evo) while gaming, fixing it at 100% (should be 2000rpm, but it reaches only 1700rpm). What happens is that it randomly falls down to 700-800rpm, making my CPU reach 65°C (OC'd FX-6300). Anyone knows why this happens?
Computer Case: NZXT S340 || CPU: AMD Ryzen 5 1600 || Cooler: CM Hyper212 Evo || MoBo: MSI B350 Mortar || RAM Vengeance LPX 2x8GB 3200MHz || PSU: Corsair CX600 || SSD: HyperX Fury 120GB & 240GB || HDD: WD Blue 1TB + 1TB 2.5'' backup drive || GPU: Sapphire Nitro+ RX 580 4GB
Laptop 1 HP x360 13-u113nl
Laptop Lenovo z50-75 with AMD FX-7500 || OS: Windows 10 / Ubuntu 17.04
DSLR Nikon D5300 w/ 18-105mm lens
https://linustechtips.com/topic/566125-command-center-fan-control-problem/
3 minutes ago, Naeaes said:
Given that they excel in pretty much everything else, Cooler Master makes surprisingly crappy fans.
So changing the fan with something like a noctua will fix this?
Maybe. Mine reaches 2000 rpm on a msi z87 no problem though.
Yeah I'll just change the fan. Just as curiosity: could it be my PSU not able to deliver enough power? I have both CPU and GPU OC'd (with 3 HDD, 1 DVD reader and 3 usb devices) and the PSU is a CX600.
its not a great PSU but your system shouldnt be beyond its capacity at all.
