Stock cpu cooler
Go to solution Solved by StevenSensei,
Yes, if you remove the cooler you should clean it and the CPU with isopropyl alcohol. Then reapply new thermal paste when you remount it. Thermal paste is not reusable.
I have a stock cooler on my i5. i want to remove the stock cooler for a bit and then install it again. to do that will i need to reapply the thermal paste or not.
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/565710-stock-cpu-cooler/
浪速の建てるは静か用に建てました!- Build Log Coming Soon!
https://linustechtips.com/topic/565710-stock-cpu-cooler/#findComment-7434430
