Hey.. So my friend just turned her pc on and this appeared on her screen. She can't proceed to boot her pc. It's just stuck here, and no matter what you press it doesnt go thru or show the problem..
We tried unplugging the power cable from psu, and taking out the motherboard battery but neither solved the problem.
So do you guys know what could be the problem, because I dont even know what to google as there is no description of the problem.
Thank you.
https://linustechtips.com/topic/565564-help-me-identify-a-boot-problem/
The primary master disk is "none" restart the PC and go into the bios and change the boot priority's to the hard drive.
Hope this helps :P
EDIT: maybe the boot disk is dead?
CPU: Ryzen 5 5600x 4.9Ghz PBO    SSDs: 250GB 850 Pro           STEAM: KezzaMcFezza
GPU: GTX 1070 Strix                                     250GB 970 Pro           MOBO: MSI MPG B550 Gaming Plus
HDD: 1TB WD Black Drive                             500GB 860 Evo          MOUSE: Logitech G502
Maybe your SATA controller has died? try another SATA port?
Asus Z77 Sabertooth, Intel Core i5 3570k 4.2 GHz, EVGA GTX 780, Corsair Vengeance 16Gb ,
Samsung EVO 250&500Gb, Western Digital Black 2TB,  Corsair RM 750
Custom Water Loop
CPU Block Koolance 380iGPU Block EKWB Clean CSQPump Laing DDC w/ EKWB X-RES 100Radiatiors NexXxoS Monsta 240 & Swiftech 240x35Tubing PrimoChill Primoflex Advanced LRT Elegant White 3/8" ID 5/8" ODFittings White Monsoon Free Centre Compression Fittings 3/8" ID 5/8" ODFans6x Noctua NF-F12 w/Noctua LNA Adaptors
Go into the BIOS, you should be able to set your normal HD as the primary drive. In case your HD doesn's show up, see if the SATA and the power connector are both connected with the HD. if they are connected, see if changing the SATA port on the motherboard helps. If everything i said doesn't work, you most likely have a dead HD.
