Fan Curves?
Go to solution Solved by W-L,
3 minutes ago, Tmt97 said:
How would one do it in bios?
It depends on your motherboard some will have the capability built right in while others are more limited. For most inside the BIOS you can set each header with a custom fan curved based on a temp probe inside the system.
Can someone explain to me how to setup a fan curve? Someone recently brought it to my attention that its ridiculous that I don't know how to setup a fan curve when my pc is fully kitted out with noctuas, but it's just not something I ever learned when I first taught myself to build PCs. If anyone could shed some light on this, I'd be most appreciative. It might also help my poor radiator to cool down if the fans actually spun faster when things warm up.
Don't do drugs. Do hugs!
https://linustechtips.com/topic/565125-fan-curves/
Try doing it in the bios. Thats what i did. Or you can get some software.
Hope this helps :P
CPU: Ryzen 5 5600x 4.9Ghz PBO    SSDs: 250GB 850 Pro           STEAM: KezzaMcFezza
GPU: GTX 1070 Strix                                     250GB 970 Pro           MOBO: MSI MPG B550 Gaming Plus
HDD: 1TB WD Black Drive                             500GB 860 Evo          MOUSE: Logitech G502
https://linustechtips.com/topic/565125-fan-curves/#findComment-7428004
Whats your motherboard?
https://linustechtips.com/topic/565125-fan-curves/#findComment-7428014
you can download msi afterburner and it allows setting a custom fan curve
Edit: im so blind. you wanted to set a curve for case fans; afterburner is only gpu. as others suggested, you can do it through bios
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/565125-fan-curves/#findComment-7428030
https://linustechtips.com/topic/565125-fan-curves/#findComment-7428036
You can use third-party software like SpeedFan, which is universal. Since you can use a Gigabyte motherboard, you can head over to their site and pick up their Thermal Console utility. It isn't as detailed and feature-rich as SpeedFan, but is far simpler and has a more user-friendly UI. Setting up a fan curve is click and drag, or you can choose from 4 built-in profiles; Quiet, Standard, Performance, and Permanent Full Speed. Personally, I use the 'quiet' profile and I think it's great. It will also allow you to adjust your CPU fan curve, to an extent.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/565125-fan-curves/#findComment-7428070
Bios settings allow you to configure it from that level. If you don't mind running extra software, speedfan is a universal choice but can be difficult to understand / configure. Here is another thread from a few years ago with a good guide to get you started if you decide to go that way.
浪速の建てるは静か用に建てました!- Build Log Coming Soon!
https://linustechtips.com/topic/565125-fan-curves/#findComment-7428118
On 3/1/2016 at 11:02 AM, AlbinoTexan said:
Nah if you get scammed you get money back so.
I downloaded speedfan, but I can't figure out how to use it. I usually pick up how to use new applications pretty quick, but the speedfan interface didn't make a bit of sense to me... Any good tutorials for it?
https://linustechtips.com/topic/565125-fan-curves/#findComment-7432336
Post on the forum or look for some on YouTube. I gave up trying to use it and just used the Gigabyte app I was talking about- it does the job for me. It even lets you set up fan curves in the UI, but the application often freezes and crashes when setting fans to fixed RPM speeds, to be wary of that.
https://linustechtips.com/topic/565125-fan-curves/#findComment-7432348
I couldnt find the gigabyte app on their website... unless its going under a different name. >.>
https://linustechtips.com/topic/565125-fan-curves/#findComment-7432805
It goes by Easy Tune for Gigabyte's system but it's fairly limited from what they've done and only offer tier to controls instead of full fan curves, you best bet would be to use Speed Fan as the others have suggested.
https://linustechtips.com/topic/565125-fan-curves/#findComment-7432904
