If my computer is powered off for more than 10 minutes, when I try to start it up it will not post and the onboard CPU led is lit up. The computer runs perfectly fine usually and will restart without any problems, it only when it has been shutdown for a while.
Clearing, or even reflashing the BIOS doesn't seem to help.
Has anyone else experienced anything similar to this?
Motherboard is Asus 990FX Sabertooth R2.0 with an FX8350.
Sorry for lack of detail, posting from mobile.
https://linustechtips.com/topic/564738-computer-will-not-post-after-cold-boot/
i have the same issue with my Gaming system i think it could possibility be down to a RAM issue i think do you have none matching RAM ? As i do and when i just have one stick of RAM in it works fine but i get around this by leaving it on the BIOS screen for a few minuets and it gose through ... hope this helps works for me till i can get some new parts.
