Hello guys i'm going to be building my first pc in the later days of march, and i would just like you to tell me if this build will work:
Cpu: Intel 6700 (non-k) and btw i will be using the stock cooler...
Gpu: Sapphire 390x tri-X
RAM: 6 or 8 gb of ddr4 g skill ripjaws RAM (also can you tell me the diffrence between 3000mhz and 2400mhz because i dont know wchich i should choose)
Mobo: Asus z170 motherboard
Case: Corsair obsidian 450d (also if there are any better cases for this build please do tell me)
SSD: Samsung 850 EVO 500gb
And also are 600W enough for this or should i go safe and get a 750W powersupply?
Thanks dudes :)
https://linustechtips.com/topic/564723-will-this-build-work/
Yes. This build will work. What's the model of the PSU?
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/564723-will-this-build-work/#findComment-7424278
http://pcpartpicker.com/part/evga-power-supply-220g20650y1
Get this.
1 minute ago, Lightswitch77 said:
Ah yes, it would be either  Corsair CX750M 750W or  Corsair CX600 600W
Novus Anima
Laptops
Surface Pro 3
https://linustechtips.com/topic/564723-will-this-build-work/#findComment-7424300
CX PSU's aren't reliable. Try this the if you're worried about price.  http://pcpartpicker.com/part/xfx-power-supply-p1650snlb9
Novus Anima
Laptops
Surface Pro 3
https://linustechtips.com/topic/564723-will-this-build-work/#findComment-7424325
Just now, Starelementpoke said:
Can you give us a site you´d be buying off of?
Uhm yes, but i would be buying from multiple stores because of prices and suck and it's all in icelandic. But we have a site that lists all computer stores and most products so here is that one: http://vaktin.is/index.php?action=prices&method=display&cid=18
https://linustechtips.com/topic/564723-will-this-build-work/#findComment-7424459
