Open Network and sharing. Then click on the house where it says network 2. Once you have done that you can change the name :)
[Case Mod] Operation: The Division --- > Here
[CUSTOM WATER COOLED TABLE] Project: Ravage ---> Here
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
https://linustechtips.com/topic/564621-lan-wired-ssid/#findComment-7423230
1 minute ago, APasz said:
First up, SSID is a wireless thing only and has almost nothing to do with wired networks.
Second, Why do you want to change it?
Third, the only way I know of changing it is through regedit
Look at what I wrote above. Thats the easiest way.
https://linustechtips.com/topic/564621-lan-wired-ssid/#findComment-7423241
Just now, 1HyperCube1 said:
Unfortunately I can't seem to do any of that on Windows 10. :( And for some weird reason my network is listed under "private network" not "home network", and I can't change it? :(
Private and Home networks are the same thing in windows. Wouldn't worry about it.
-アパゾ
https://linustechtips.com/topic/564621-lan-wired-ssid/#findComment-7423282
Well sorry about that. Check this out it tells you how to do it exactly.
http://www.tenforums.com/tutorials/6815-network-location-set-private-public-windows-10-a.html
https://linustechtips.com/topic/564621-lan-wired-ssid/#findComment-7427368
