Cache clock speed, does it really matter?
Hi all.
So, after several months of owning my CPU, I'm still fine tuning my overclock. I found that with RAM at 1600, my CPU does fine at 4.4 GHz with 1.250 vcore. However with RAM at its XMP of 1866, I need a bit more vcore to be completely stable. I want to keep my XMP, so I thought I'd push my vcore to 1.3 and push my cores to 4.5, because if I'm going to increase the voltage anyway I might as well get what I can out of it.
My question is, should I bother overclocking my cache speed or not? I've heard a lot of mixed opinions on this. Is it possible overclocking my cache will take away from my core stability?
https://linustechtips.com/topic/564493-cache-clock-speed-does-it-really-matter/
It helps a tiny bit, but not very much, more in benchmarks, rather than games.
It shouldn't hurt core stability, but it can affect overall stability.
IE:  Running stock cache vs OC cache, you shouldn't need to lower your CPU multiplier to get a higher cache ratio to work.   (In my experience at least.)
Thanks for the input. Does cache voltage affect temps a lot? For example, if my cache voltage is 1.3 would I see a large increase in temps?
I think its different as Haswell chips have the voltage regulator built onto the  cpu which made them get hotter than say skylake 6600k which I run. I know with Haswell Refresh they did sort the Thermal Interface Material so it made it cooler. The Evo 212 is a well renowned great cooler. Maybe give it a go and see if the heat rises but don't leave your computer while u do this just sit by it for say 15 mins while you test what u amended.
