You have to set it up, it is very complicated to do.
You will have to look up a guide, I am no expert. I have set speedfan to control a single fan and it took me a while. Also your mobo has to have actual 4pin PWM signal, sometimes the only header with true PWM is the cpu_fan.
https://linustechtips.com/topic/564354-using-speed-fan/#findComment-7420528
CPU: me | Dark Rock Pro 3 | Asus Z170-A | 32GB Dominator Plats | 512gb SSD/4TB WD Black | 980Ti | BQ Silent Base 800 | EVGA 850w |
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
BEST PC FOR THE PRICE:
$400 $500 $600 $700 $800 $900 $1000
If you want to Silence your PC/Room more, contact me.
https://linustechtips.com/topic/564354-using-speed-fan/#findComment-7420568
Speedfan is actually really simple to set up and use, and because it works off the motherboard chips, it can control both PWM and voltage controlled fans without any issue. I used it with my old Athlon 64 x2 Acer to keep it quiet.
Once the program is open, go to Configure -> Advanced tab -> Then using the dropdown list next to "Chip", click through them until you see one that has more than just "Temperature offset" listed (My Gryphon Z97's chip lists "PWM 1 Mode") -> Click the one you want to change (Find the right one using trial and error if you want a specific fan) and then from the dropdown list select "Manual" -> Press OK and set the speed in the main window
LTT's fastest Valley 970, slowest Valley Basic and Extreme HD scores
Desktop || CPU - i5 4690k || Motherboard - ASUS Gryphon Z97 || RAM - 16GB Kingston HyperX 1866MHz || GPU - Gigabyte G1 GTX 970 *Cough* 3.5GB || Case - Fractal Design Define R5 || HDD - Seagate Barracuda 160GB || PSU - Corsair AX760
https://linustechtips.com/topic/564354-using-speed-fan/#findComment-7420609
