On 12.03.2016 г. at 9:21 PM, Fawful Rox said:
~snip~
Hey Fawful Rox,
The best way would be to check the drive's condition by running a diagnostic tool from the manufacturer and then confirm these results with a third-party tool that can give you the raw values of the S.M.A.R.T. status. If you are not sure how to read them feel free to post them here. :)
What's the drive's brand and model?
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/564298-hard-drive-question/#findComment-7429151
12 hours ago, Captain_WD said:
Hey Fawful Rox,
Captain_WD.
WD
https://linustechtips.com/topic/564298-hard-drive-question/#findComment-7433266
On 15.03.2016 г. at 2:32 AM, Fawful Rox said:
~snip~
In that case I'd recommend using WD Data Lifeguard Diagnostic tool and see if the drive passes both the quick and the extended tests. :)
Again, checking the raw values of the S.M.A.R.T. status is also a good idea and yo can feel free to post them here (without the serial number of the drive) if you are not sure how to read them. :)
Captain_WD.
https://linustechtips.com/topic/564298-hard-drive-question/#findComment-7441012
