Do I get to keep csgo operation maps in csgo?
13 hours ago, Rob.S said:Hi all,
i have a very important question about csgo, would appreciate a fast reply. Do I get to keep the operation wildfire maps after it ends, even if I didn't buy a pass? The vanguard maps were amazing, but then they just vanished!!!! I didn't get to buy a pass... Can I keep the maps if I don't buy a pass?
Also when does the wildfire operation end? Can't find it on google
all replies welcome!
12 hours ago, Rob.S said:Thanks everyone! I will back up all the map files, as for Vanguard they vanished from Offline with bots as well :(( can someone tell me where the files are in the game folder? I don't wanna lose more maps.
You can find the all the maps on the workshop. Then you just have to subscribe to them and you will get updates for them (unless they get taken off the workshop for some reason, which is really unlikely). You can find the older operation's maps on the workshop as well.
But, the files are in "Steam\SteamApps\common\Counter-Strike Global Offensive\csgo\maps" if you want to manually back them up anyway.
The operation ends June 17th.
