Regex Help
Go to solution Solved by denarced,
I might be able to help but I don't know what kind of regex engine is used in Minecraft chat. If it has all of the fancy features that Perl has then this should work.
I'm working on a chat filter for minecraft and need to stop people from character spamming in the chat. An example of what people type is this: "Heeeeeeeeyyyyyyyyyyyyyy guuuuuuyyyyyyyysssssssssss!!!!!!!!!!!!!!!!!!" I want to limit people to only saying a single character 6 times in a row (aaaaaa) using regex. You can use https://regex101.com/ to help with this but I couldn't figure out exactly how to do this. Here are some examples that would NOT be blocked: "heyyy, wazzzup, !!!!" Here are some examples that WOULD be blocked: "!!!!!!!!!!!!!!,HEYYYYYYYYYYYY,NOOOOOOOOOO" If you can help me with this, I'm sure it's quite simple and I just couldn't find something, I would appreciate it. Thanks!
My main computer:
i7 6700k || GTX 1070 || Asus Z170 RGB || C.M. Hyper 212 EVO || 16GB RAM || 256GB NVMe SSD || 500GB SATA SSD || 12TB total HDD || Define R5 Blackout || 850W PSU
More Details Below :)
CPU: Intel Core i7 6700k                             GPU:  EVGA GTX 1070 FTW                                  |  Motherboard: Asus Z170 Pro Gaming Aura
CPU Cooler: C.M. Hyper 212 EVO             RAM: 16GB Kingston Fury 4x4 DDR4 2400MHz         SSD:  Intel 256GB NVMe SSD & Plextor 500GB SATA SSD
Hard Drive:  WD 2TB Black, 2TB WD Blue, 8TB WD Red     Case:  Fractal Design Define R5 Blackout Edition   PSU:  Be Quiet! Dark Power Pro 11 850W
Additional Computer Parts: NZXT Hue for LEDs
Peripherals: Dell U2414H (x2) || Corsair Sabre RGB || Corsair K95 Platinum || Sennheiser 558's || Modmic
Pictures of setup:
https://linustechtips.com/topic/564194-regex-help/
i7 3770 | Asus GTX670-DC2-2GD5 | Kingston HyperX Blu 16 GB | Samsung 850 Evo 1TB
Fractal Design Define R4 | Nexus RX-8500 850W | Asus P8Z68-V-PRO/GEN3 | 2 x Asus 24.1" PA248Q
“An expert is a man who has made all the mistakes which can be made, in a narrow field.” – Niels Bohr
https://linustechtips.com/topic/564194-regex-help/#findComment-7418830
Thanks, that worked, sorry for late reply.
My main computer:
Pictures of setup:
https://linustechtips.com/topic/564194-regex-help/#findComment-7418984
