Hi,
I plan on building my first gaming PC. Can somebody please validate my build, Im not sure if I'm spending too much on things like the motherboard.
The MSI gaming M5 or M7 would be an option too, but I like the fan and lighting control features of the Asus motherboard.
The psu's wattage is quite high if I decide to throw a second 980 ti into the rig.
What do you think about it?
Where can I save some bucks? How does the Asus Strix compare to the Gigabyte graphics card?
PCPartPicker part list: http://pcpartpicker.com/p/62md3C
Price breakdown by merchant: http://pcpartpicker.com/p/62md3C/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($379.99 @ Newegg)
CPU Cooler: Corsair H110i GTX 104.7 CFM Liquid CPU Cooler  ($99.99 @ Newegg)
Motherboard: Asus ROG MAXIMUS VIII HERO ALPHA ATX LGA1151 Motherboard  ($282.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($79.99 @ Amazon)
Storage: Samsung 950 PRO 512GB M.2-2280 Solid State Drive  ($327.00 @ Newegg)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($676.98 @ Newegg)
Case: Corsair Carbide Clear 600C ATX Mid Tower Case  ($129.99 @ Micro Center)
Power Supply: Corsair 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($148.79 @ Newegg)
Total: $2097.72
Generated by PCPartPicker 2016-03-12 10:01 EST-0500
https://linustechtips.com/topic/564187-first-pc-build/
The motherboard is a bit on the overkill side, maybe go for a cheaper one but whatever suites your needs :P and the power supply is a bit overkill for that system as well. but if you plan on using two 980 Ti's in the future then yea that power supply is fine.
Hope this helps :P
EDIT: Maybe go for 16 GB ram 8GB is quite shit for a 2000 dollar system xD
CPU: Ryzen 5 5600x 4.9Ghz PBO    SSDs: 250GB 850 Pro           STEAM: KezzaMcFezza
GPU: GTX 1070 Strix                                     250GB 970 Pro           MOBO: MSI MPG B550 Gaming Plus
HDD: 1TB WD Black Drive                             500GB 860 Evo          MOUSE: Logitech G502
https://linustechtips.com/topic/564187-first-pc-build/#findComment-7418672
