Hello every one,
I'm having an issue with my boot sequence and have tried everything I know to fix the issue.
So I'm turning to you all for some help and maybe some one will have the answer it could be an easy fix but I myself have never had to deal with this issue before so I'm stumped.
Essentially what happens is anytime the Computer does a restart either after I install software or even a random forced restart due to a Windows update my computer will not boot back to the OS it sends me to a black screen with a Command prompt line that just blinks. It doesn't have any commands it's just the line.
I have to hard restart the PC and hit F11 to get to the boot drive selection to select the drive that has my OS on it and than it will boot in.
If I shut the PC down myself it doesn't have this issue it will boot back up fine no problems.
I have gone to the bios and arranged the drives so my OS drive is the first in the list thinking that would fix the issues since it would be the first Drive it sees but that didn't help idk if I'm missing something else or what.
I'm hoping some one can help me out i would really appriciate it and enjoy not having to deal with this hassle and more.
Thank you every one.
https://linustechtips.com/topic/563795-please-help-with-my-boot-sequence/
29 minutes ago, Offcrnaughty said:
Hello every one,
try updating the bios since it could be the factory one on the board. my x99 doesn't support m.2 ssds if i don't update it
Main build
CPU: i7 5820k  MotherBoard: Gigabyte x99 UD4  RAM: corsair ballistix 2400mhz 4x4gb  GPU: Asus GTX 970  PSU: corsair rm1000  SSD 1: Samsung 840evo 500gb  SSD 2: Samsung 850evo 500gb  HDD: Western Digital red 3tb  Case: Phanteks Enthoo pro M  CPU cooler: corsair h80i
Second build
CPU: i7 5820k  MotherBoard: Gigabyte x99 UD5 WIFI  RAM: G.skill 2666mhz 4x4gb  GPU: Nvidia GTS 450 (soon to be upgraded)  PSU: corsair HX650  SSD: Samsung 850evo 250gb  Case: Cooler Master 430 elite  CPU cooler: Cooler Master hyper 212 evo
Third build
CPU: xeon x5690  MotherBoard: Evga x58 classified 4way-sli  Ram: Patriot 1600mhz 4x3gb  GPU: Asus HD6970  PSU: fractal newton r2 1000w  SSD: crucial m500 240gb  Case: Cooler Master Haf X  CPU cooler: Mega Shadow
OK I will give this a shot it was a pre-built pc the MOJO isn't a really high end board it's just a simple gigabyte one and no SSD just a standard HDD but will still give this a shot thank you very much!
before you do anything, when did you buy it?
Main build
Second build
Third build
10 hours ago, Offcrnaughty said:
I bought it about 2 years ago
yea just update it, was thinking you could replace it but seems to be kinda late for that
Main build
Second build
Third build
1 hour ago, Offcrnaughty said:
OK thank you I'm going to be giving it a shot today I will post back with results. Thank you xD
just quote me so i can find back c:
Main build
Second build
Third build
