Hi.
I changed the psu of my PC today. The ,12 V is behind the cooler.  The wire was a little short . so after pushing against the cooler i decided to take it off. While taking off my cooler the CPU came with it. With the lever locked.The CPU is dead. Many bend pins and 1 broken one. I had an old CPU lying around. Witch had bend pins also before. I put it into the socket. It van still be locked. So it doesn't sit loose. I reattched everything  and tried to boot. It didn't. Fans start spinning and lights flash. But nothing appears on the screen. Not even the oem logo.
Did i wrecked the socket? Or do i need an new cpu?
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/563746-need-help-urgently/
