Bitfenix Case Radiator Help
Go to solution Solved by W-L,
On 3/11/2016 at 8:07 PM, HeroXLazer said:
What are the radiator+fan thickness dimensions for both the 240mm slots and the 120/140mm fan slots?
I'll be running dual dual slot gpus...
Also the case... Bitfenix Phenom M-ATX
It doesn't look like you can fit a rad setup up there as there is only enough space with dual GPU's for only fans:
http://www.techporn.ph/bitfenix-phenom-m-micro-atx-chassis-review/
BitFenix Phenom M Review (35)
