Right click on CSGO in your steam library, go to properties and under the General tab, click on launch options.
Let's say I had a 1920 x 1080 monitor, and I wanted black bars to make it 4:3. keeping the 1080 vertical resolution, and changing the aspect ratio makes it 1440 x 1080. So:
Type into launch options:
-w 1440 -h 1080
Restart CSGO and go to video, set aspect ratio to 4:3 and set resolution to 1440 x 1080.
Your resolution may vary depending on what monitor you have.
QUOTE ME IF YOU WANT ME TO REPLY
Le USD $300 Second Hand Potato
CPU: Intel i5-750 @ 3.8GHz Motherboard: Intel DP55WG RAM: 12GB Corsair Budget 1333MHz (2x2GB+2x4GB) GPU: Sapphire Radeon HD 5750 512MB Case: Cooler Master Elite Storage: Seagate Barracuda 500GB PSU: Cooler Master Generic 500W (came with case) Displays: 21.5" 1080p Acer G226HQL Cooling: Cooler Master Hyper 212 Evo Keyboard: Corsair K70 RGB (Mx Reds) Mouse: Logitech G502 Sound: Turtle Beach X12's Operating System: Windows 10
Yep... My peripherals cost me more than the rig itself. ¯\_(ツ)_/¯
https://linustechtips.com/topic/563258-csgo-amd-stretched-help/#findComment-7408097
-w 1440 -h 1080
that didnt seem to get it. It still starts in black bars :'(
https://linustechtips.com/topic/563258-csgo-amd-stretched-help/#findComment-7408192
Wait, do you want black bars or not?
Is it that you have a 16:9 monitor, and want 4:3 unstretched or stretched?
https://linustechtips.com/topic/563258-csgo-amd-stretched-help/#findComment-7408205
I dont want the black bars, i have a 16:9 monitor and whenever i go into the game it changes the settings to preserve aspect ration :'(
https://linustechtips.com/topic/563258-csgo-amd-stretched-help/#findComment-7408220
So you want want a 16:9 monitor to display a 4:3 image stretched back to 16:9...
WHY?
https://linustechtips.com/topic/563258-csgo-amd-stretched-help/#findComment-7408227
WHY?
it actually makes the targets bigger in the game, many of the pros use it and i have learned to like it... then amd came out with an update :'(
https://linustechtips.com/topic/563258-csgo-amd-stretched-help/#findComment-7408234
Dude, it's not good for your muscle memory. Stretching the image like that means that moving your mouse will appear to be more sensitive on the horizontal axis, yes the targets will be wider, but the fact that your mouse is now inherently more sensitive on the horizontal axis (because of the way the screen is stretched) means it can be HARDER to hit the targets. Visibility is best on native resolution and native aspect ratio.
https://linustechtips.com/topic/563258-csgo-amd-stretched-help/#findComment-7408249
Most of the pros use it because of how CS 1.6 handled monitor scaling way back in the day, and they're so used to that, they would lose their edge if they tried to change back to normal scaling.
https://linustechtips.com/topic/563258-csgo-amd-stretched-help/#findComment-7408260
