Best bang for buck small GPU
Nonco
Was looking at some of the low profile 750Ti's for a M-ITX build im planning. What other good options are there for a small GPU?
EDIT: Cheaper is better. All id be playing would be Dota 2.
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
What processor are you looking at? Amd apus are good for this stuff
Was probably planning just a G3258, trying to keep it as cheap as possible.
APU could be an option. I forget, if I get an APU, they can work together with an AMD card if i got one too later yeah?
My Rigs:
Case:
Case:
Yeah, a amd a10 7870k or 7850k (or if you really want to, a 7890k when it comes out) apu works good, and you can dual with a 250 which you can find in low profile form, which boosts performance even more
On March 9, 2016 at 3:36 PM, max_headroom said:
3258 + 750ti = perfect low budget pc
1080p mid settings 45-60fps.
Yeah, but now with the 7890k out dualing with a 260 might be possible
Even the G3258, without a GPU, is already enough to power that game. If you are looking to go super cheap now (with the possibility to upgrade), then that's a great option.
Otherwise, if you want a bit more juice and don't intend to ever touch that PC again, while still being on the cheap, go with the APU route.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
