Help plz
Go to solution Solved by tataklee,
1 hour ago, Naes_ said:
Woah the forum is shiny...
Can you guys help me figure out the parts used in the build..
Is the motherboard the Deluxe or the Pro?
And where can I find those pretty white cables :3
He says the parts. Even though he says the motherboard was an Asus X99-A, it really is the X99-Pro, it's even printed on it. He must be just as confused as you are. The cables themselves are from Corsair.
http://m.newegg.com/Product/index?itemnumber=N82E16812304008
Motherboard: Asus X99-PRO/USB 3.1 ATX LGA2011-3 Motherboard  ($321.99 @ SuperBiiz)
Total: $321.99
Generated by PCPartPicker 2016-03-08 03:53 EST-0500
~SNIP~
without actualy watching the video(too lazy)
its a asus x99 delux or such board. Theres different versions of the board, but I cant really tell without specs.
its got a x99 cpu
NZXT H440
corsair h100i/h110i/h110gt cpu cooler(again different versions)
Refrence GTX 950/960/970,(also, the title says 2016, so im assuming its not the 7xx series)  since it does not have a GPU backplate. the 980 and 980ti refrence have stock backplates( again i can not tell which specific gpu
Corsair SP whiteLED fans(because hed be a dumbass to put af led fans on it. also, you can see the physical led)
Corsair vengeance ram.
also, I hate you
just played the video.
WATCH THE FRIGGIN VIDEO. HE SAYS THE PARTS
JESUS CRIST MAN
/s
https://linustechtips.com/topic/561661-help-plz/#findComment-7388307
Cables are from CableMod ( cablemod.com )
The Graphics card is a 980 Ti
I'm pretty sure the board is a Deluxe
The CPU is most likely to be a 5820K($380ish), 5930K($499ish), or a 5960X($999)
The Cooler I'm certain is a Corsair H100i GTX
The PSU is an HX850i
The RAM (doesn't REALLY matter, imo)
https://linustechtips.com/topic/561661-help-plz/#findComment-7388308
Total: $321.99
https://linustechtips.com/topic/561661-help-plz/#findComment-7388571
