Software not controlling a Fan
Go to solution Solved by LogicalDrm,
Yes and no. Yes its reason why you can't just control it like you would with PWMs. But no, that doesn't mean you can't control it. Set fan header control in BIOS to DC/voltage, if possible. You should be able to use curves or fixed speeds with some limits. Like fan not being able to run under certain (30/40%) speed and jumps in rpm being bigger than with PWMs.
in my old PC i have an i5-4460 and an asrock H97M Pro 4. the fan connectors labeled "cha_fan1" and cha_fan2" are able to be controlled by the A-Tuning software. i can control cha_fan1 but not cha_fan2. cha_fan2 is a 4 pin PWM connector and the fan (Be Quiet! Pure Wings 2) is only a 3 pin. is that the reason why i cannot control cha_fan2?
CPU: me | Dark Rock Pro 3 | Asus Z170-A | 32GB Dominator Plats | 512gb SSD/4TB WD Black | 980Ti | BQ Silent Base 800 | EVGA 850w |
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
BEST PC FOR THE PRICE:
$400 $500 $600 $700 $800 $900 $1000
If you want to Silence your PC/Room more, contact me.
https://linustechtips.com/topic/560960-software-not-controlling-a-fan/
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Thanks for the help! :) also thanks for replying to my other topic, you helped me as well :)
