Sounds like our RGB lighting if perfect for you, you can find all our RGB products > here <.
Are you also wanting lighting in your case?  If you are then I suggest one of our small RGB kits, an extension RGB strip (I suggest 1meter) and a RGB extension cable, then you can use the kit inside your case, and then use the RGB cable to plug into the kit, and run that outside your case and attach it to the RGB strip. That way you can use the remote that comes in the kit to control all the LEDs both in your case and on your desk.
If you need just lighting for your desk then I suggest one of our bigger kits > Here <
Let us know if you have any questions
Reviews of our products by LTT forum members can be found in the spoiler below :)
LTT Member Lays done a quick review here - Click Here
LTT Member jtai117's review can be found here  - Click Here
LTT Member W-L done a review, topic is here - Click Here
LTT Member KillerTechs review can be found here - Click Here
LTT Member FunkyFeatures review can be found here - Click Here
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
https://linustechtips.com/topic/560341-desk-led-lighting/#findComment-7374949
