I'm assuming it's a single card, right? Because dual card setups have been having some... issues... with the SteamVR test.
How are the system's usages, clocks, and temps (GPU and CPU) while running the test?
"Do as I say, not as I do."
-Because you actually care if it makes sense.
Ill run the test again monitoring those
Yes single card.
Dash, CPU temps got to about 37 compared to the normal 25 or so, and GPU temps got to about 39 from the norm 28.
GPU usage was at 99 for the entirety of the test.
CPU usage seemed the norm.
Hmmm... That's strange...
Could you list the full specs?
Also, did you monitor the clocks as well?
Alright after trying multiple times,
My system completely locks up if i try and have both HWiNFO and the SteamVR test running at the same time.
... Um... Well.
Do you have any other monitoring software installed, like Corsair Link?
Also, what are the full specs?
ASUS M5A99FX PRO R2.0
AMD FX 8350 Eight-Core Processor 4.3 GHz
NVIDIA GeForce GTX 970 4.0 GB
8.0 GB DDR3 (2x4)
Crucial 250GB SSD
Corsair 650W PSU
1TB WDC drive
and another 750GB drive
8.0 GB DDR3 (2x4)
Crucial 250GB SSD
1TB WDC drive
I asked if you have Corsair Link because it can cause a conflict with other monitoring software, I do hope you didn't just install it...
Either way, that is pretty confusing. Have you tried wiping graphics drivers and reinstalling them?
That's only Nvidia SLI. Crossfire is working fine with SteamVR. I realize OP has a 970, just putting it out there that its only an SLI problem.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
Well, yeah, but... This guy has an Nvidia card. That isn't really relevant here.
