Mkay, so basically I have got everything that I need, but I need help to check the compatibility with all of the systems, eg if the CPU can even be put into the motherboard. So yea. Here are the links.
CPU : http://www.amazon.com/gp/product/B015VPX2EO?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=ATVPDKIKX0DER
PSU : http://www.amazon.com/gp/product/B00H33SFJU?psc=1&redirect=true&ref_=ox_sc_act_title_3&smid=ATVPDKIKX0DER
HDD : http://www.amazon.com/gp/product/B005T3GRNW?psc=1&redirect=true&ref_=ox_sc_act_title_4&smid=ATVPDKIKX0DER
RAM : http://www.amazon.com/gp/product/B006WAGGUK?psc=1&redirect=true&ref_=ox_sc_act_title_5&smid=ATVPDKIKX0DER
GPU : http://www.newegg.com/global/nz/Product/Product.aspx?Item=N82E16814500349
Motherboard : https://www.mightyape.co.nz/product/Asus-H110M-A-Motherboard/24106094
Case : https://www.mightyape.co.nz/product/Deepcool-Tesseract-Mid-Tower-Case/24164486
PLEASE NOTE : I DO NOT want to go over the current price which is $832 NZD but if anyone could just help me to see if all of these are compatible that would be amazing. Thanks in advance :)
https://linustechtips.com/topic/559886-need-help-with-compatibility/
You should really use pcpartpicker. It would make things much easier for you.
Just now, tataklee said:
You should really use pcparticker. It would make things much easier for you.
PCPartPicker is a very expensive option for me because I come from New Zealand and everything is 30% more for whatever reason when it comes to shipping. So that's why I don't use that. And I was also more so wondering how the CPU would perform against other CPU's like the AMD FX-6300
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($197.00 @ 1stWave Technologies)
Motherboard: ASRock H110M-DGS Micro ATX LGA1151 Motherboard  ($102.35 @ PB Technologies)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  ($82.23 @ Aquila Technology)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($87.37 @ Aquila Technology)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card  ($237.00 @ Paradigm PCs)
Case: Deepcool TESSERACT SW ATX Mid Tower Case  ($86.63 @ Wiseguys)
Power Supply: SeaSonic 450W 80+ Gold Certified ATX Power Supply  ($146.82 @ Ascent Technology)
Total: $939.40
Generated by PCPartPicker 2016-03-06 00:18 NZDT+1300
Ok, get ddr4 ram like this: https://www.mightyape.co.nz/product/2x4GB-Kingston-HyperX-FURY-2133Mhz-DDR4-RAM-Black/24084463
1 minute ago, Matty2hatty said:
From what I am seeing it is just cheaper to get this : http://www.amazon.com/gp/product/B006WAGGUK?psc=1&redirect=true&ref_=ox_sc_act_title_5&smid=ATVPDKIKX0DER
Is there any reason why I should be getting the Fury Ram over the original ones?
Hey man, I'm from Australia, Count me as your next door neighbor :P, I use pcpartpicker to confirm all the parts are compatible, I have a friend from NZ and i was helping him do a build, it was cheaper for him ( at the time ) to buy from Australia at Pc case gear. I highly recommend that online store, make sure you check compatibility if you're unsure @ Pcpartpicker and work out if its cheaper to buy from an Aus store. Who knows you might be able to get more with your budget. I trust you'll be able too look at Exchange rates / Shipping / Insurance for shipping / and put that into consideration as well. Hope this helps.
-TPG
-TPG
This website is a tremendous help, however I do not believe I can ship to New Zealand from it :( If you don't mind me asking, how did you send it to your friend in NZ from the store?
-TPG
And actually never mind it would cost the same either way because of shipping but thanks so much for your help :)
