Here is my current pc specs
PC SPECS
Is there any bottleneck in my current setup? Not sure if i need a little or big upgrade?
Mainly only play Dota 2 And BF4 games like that
**My PSU is Corsair TX650v2
AMD FX 8320 @3.9Ghz|16GB Patriot Viper Red 1600Mhz (DDR3)|Palit GTX 770|GigaByte GA-970A-DS3P
|Antec 1100|NZXT Havik 140|Corsair TX650v2|3 x 24 inch|Razer Deathadder Chroma |CM Quickfire TK (Blue)
https://linustechtips.com/topic/559374-possible-system-upgrade/
Mehhh you're good
Everyone will ask you to upgrade to intel but your current system should be fine for your needs
Probably will upgrade gpu to something like a 380 if i had to
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/559374-possible-system-upgrade/#findComment-7360520
22 minutes ago, HatsuneMilku said:
No bottleneck. Nothing to really upgrade now except maybe another ssd or upgrade to a 970 if you want.
How much more of a fps increase % would i see with a 970
https://linustechtips.com/topic/559374-possible-system-upgrade/#findComment-7360713
22 minutes ago, xnoobftw said:
Mehhh you're good
Ive always loved amd, so all in all my current setup is fine?
https://linustechtips.com/topic/559374-possible-system-upgrade/#findComment-7360718
Yes it is
https://linustechtips.com/topic/559374-possible-system-upgrade/#findComment-7362297
Don't upgrade your GPU now, Polaris/Pascal right around the corner. Unless you absolutely hate the performance of your system it's fine for the time being IMO (assuming you're playing at 1080p).
If you had to upgrade, GPU would be the best route, and R9-390/X > 970.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/559374-possible-system-upgrade/#findComment-7363219
PC SPECS
You dont really need any real upgrade. for the games you play your system is fine.
If you would like some more fps yeah you could try a gtx970, how much more fps you wil get.
CPU:  fx8320 4.5Ghz  Motherboard: Asus M5A99x EVO R2.0  GPU: Asus Nvidia GTX 970 strix  Cooler: Corsair h60  RAM: G-Skill Ripjaws z 32gb
PSU: Be Quiet! Straight power 500w  SSD: Samsung 840 evo 250gb  HDD: 320gb - 500gb - 1tb
Firestrike score: http://www.3dmark.com/fs/7844872
https://linustechtips.com/topic/559374-possible-system-upgrade/#findComment-7363747
