Warped Camera Sony Z3
Go to solution Solved by piemadd,
30 minutes ago, Haammaar said:
yeah
I just googled it. You can't fix it. It's because of how the lens is made. If it makes .mp4 files, you can try doing it through the GoPro editor. There is a setting to do it there.
