Hello, I have this VBScript here. It's made to login on a website (School site, they have made it a pain in the ass to login beacuse it's like several different pages and tons of usless buttons to click to get there)
I've gotten the script to work as I want but the problem is that it opens in IE. I know Chrome doesn't support VBScripts but I've read some about tricking it to use it. Or is there another good way to create a script to do all this script does. (Most important is I don't want to use any "Sleep" because the main reason is to get the fastest login time the connection can handle, and as that varies it's hard to use any timings)
Set IE = WScript.CreateObject("InternetExplorer.Application", "IE_")
IE.Visible = True
IE.Navigate "http://google.com"
Do
    WScript.Sleep 500
loop While IE.ReadyState < 4 And IE.Busy
IE.Document.getElementByID("username").value = "user"
IE.Document.getElementByID("password").value = "pass"
IE.Document.getElementByID("Submit1").Click
WScript.Sleep 5000
Dim LinkHref
Dim a
LinkHref = "link"
For Each a In IE.Document.GetElementsByTagName("a")
  If LCase(a.GetAttribute("href")) = LCase(LinkHref) Then
    a.Click
    Exit For  ''# to stop after the first hit
  End If
Next
FX-8350 GTX760 16GB RAM 250GB SSD + 1TB HDD
"How many roads must a man walk down?" "42"
https://linustechtips.com/topic/558954-vbscript-problems/
Not sure about VBScript but you could create a bookmark with javascript that did what you wanted, unsure of what your foreach loop is supposed to do at the bottom but the first part of the code is super easy
window.location.href = "http://www.google.com";
while (document.readyState !== "complete");
document.getElementById("username").value = "user";
document.getElementById("password").value = "pass";
document.getElementByID("Submit1").Click();
https://linustechtips.com/topic/558954-vbscript-problems/#findComment-7355055
I've probably just messed up the loops at the bottom (I'm very new to VBScript so it has been alot lf trial and error coding) but what if the code I have under the first part? That one is intended for another page that loads where it searches for a link. Will I have to load a new script for that site or can I make the first one continue to the new page with similar form filling/button clicking code?
https://linustechtips.com/topic/558954-vbscript-problems/#findComment-7355832
1. Chrome doesn't support VBScript:
You're right, but it doesn't support VBScript running inside of a webpage... the script you have is running outside of the browser and by the Operating System instead, so modifying the CreateObject line might work depending how Chrome's built & what it's API exposes (i.e. I've never checked if there's Chrome.Application or similar you can pop in there myself).
2. Another way of performing that same workload:
Yes, you have a few options. A test automation tool such as Selenium (free) or a client process automation tool like AutoHotKey (also free?) will work too. For the most part, what's suggested above with bookmarking the page in your browser and asking the browser to save the logon credentials will make all of that script apart from 1x last link click, obsolete.
3. Alternative to sleep
Here you're using a scripting language and realistically the only way to interact with the browser's state is via that IE object's properties. IMO if you're using this script, you need the waits, but (i) can keep the increment counter to something low like 500 and stick it inside of a loop like you're doing with the top wait instance "loop While IE.ReadyState < 4 And IE.Busy" - this will lead to the script and potentially the OS being unresponsive until the browser page has refreshed and the page content has loaded (depending on the value passed in https://msdn.microsoft.com/en-us/library/ms534361%28v=vs.85%29.aspx?f=255&MSPPError=-2147217396).
If you went the TA tool way, Selenium has assertions (other tools have what's known as chekpoints) which let you write loops which say "whilst the string 'welcome, logged in user Alex' hasn't yet appeared on the page, wait".
4. What does the bottom loop do:
It searches for a link in the format <a href="link">SomeTextHere</a> (where I'm guessing the proper value of the "link" part has been stripped out for this web posting). When that link is found, it's clicked on and the loop exits. Basically it's performing a search and click on a single hyperlink inside of the 2 webpage (that presented after the login).
https://linustechtips.com/topic/558954-vbscript-problems/#findComment-7359251
LinkHref = "http://www.google.com";
var elements = document.getElementsByTagName("a");
for(var i = 0; i < elements.length; i++)
    if(elements[i].getAttribute("href").toLowerCase() == LinkHref.toLowerCase())
        elements[i].click()
        break;
So basically @xQubeZx add this as a bookmark (just replace the LinkHref, username and password, window.location.href values)
javascript:window.location.href = "http://www.google.com"; while (document.readyState !== "complete"); document.getElementById("username").value = "user"; document.getElementById("password").value = "pass"; document.getElementByID("Submit1").Click(); LinkHref = "http://www.google.com"; while (document.readyState !== "complete"); var elements = document.getElementsByTagName("a"); for(var i = 0; i < elements.length; i++){ if(elements.getAttribute("href").toLowerCase() == LinkHref.toLowerCase()){elements.click()}}
Edit: fixed a couple of bugs
https://linustechtips.com/topic/558954-vbscript-problems/#findComment-7360199
