12 minutes ago, HeyItsAlfie said:
gtx 750 ti s have a bad reputation
Since when?
15 minutes ago, netherbawss235 said:
My friend wants me to build a computer for him. His budget is $400, I have made a build for him but I want your advice. How is this build: http://pcpartpicker.com/p/ghcm4D
Looks great, just change it to 8GB RAM.
You could consider an Athlon instead but thats dependant on if you need the extra cores.
https://linustechtips.com/topic/558609-build-for-a-friend/#findComment-7351387
No they don't. It's a great budget card.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/558609-build-for-a-friend/#findComment-7351404
Better GPU and better PSU. The Pentium is strictly two cores (which a handful of games don't like), so I'd get a four core Athlon instead.
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($72.89 @ OutletPC)
Motherboard: Asus A68HM-E Micro ATX FM2+ Motherboard  ($40.98 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory  ($29.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: EVGA GeForce GTX 950 2GB Superclocked Video Card  ($139.99 @ Newegg)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case  ($26.99 @ NCIX US)
Power Supply: XFX XT 400W 80+ Bronze Certified ATX Power Supply  ($30.98 @ Newegg)
Total: $388.71
Generated by PCPartPicker 2016-03-02 18:49 EST-0500
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/558609-build-for-a-friend/#findComment-7351444
Just now, GetShrektMrKrabs said:
@HKZeroFiveMy build for him is very similar. I added an SSD for the OS and some games to make up for the cheaper CPU. http://pcpartpicker.com/p/zMLj3C
I wouldn't get that PSU. The EVGA 400W White is pretty bad. XFX or SeaSonic is the way to go.
https://linustechtips.com/topic/558609-build-for-a-friend/#findComment-7351475
