Hey guys I got 2 ASUS strix 980ti's in my rig, and for some reason they are both way below their normal clock speed of ~1250MHz. Instead they hitting a max of 595MHz and an avg of 405MHz.
What is going on??? Can someone help me? I cannot even play the simplest games at 30fps when Im usually around 100fps+
Thanks in advance! Jar
Intel i7-5820k OC'ed to 4.2GHz @1.225 V; w/ Corsair H110i GTX2x Asus Strix 980ti's; Asus Rampage V Extreme; 16GB (2x8GB) Crucial Ballistics GDDR4 RAM; EVGA 1000P2 psu
http://www.3dmark.com/3dm/8608142 boost clock of 1493MHz
https://pcpartpicker.com/user/jjar35/saved/#view=ghCWGX + 43" 4k Vizio M-Series TV
https://linustechtips.com/topic/558416-gpu-clock-speed-way-below-normal/
I would test the cards in a different machine if you have the ability, if they work in another computer your problem probably lies in your PSU or motherboard. Do you know your thermals? They could even just be throttling due to poor ventilation if you're running the two cards in a small case.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
One thing you might try, is running one card at a time to see how they perform then. If they both run at normal speeds when they are in there solo, the issue may be SLI-related. Or as Spork829 suggested it may be a heat issue. Multiple high-end cards in close proximity can be prone to overheating if the air around them is not adequately circulated. To this end, you will want to keep an eye on the GPU temperatures.
daily driver
Intel Core i7-950 | ASUS SABERTOOTH X58 | 6x2GB Corsair XMS3 PC3-12800 | ASUS GTX970 STRIX | SB X-Fi Titanium
Samsung 840 EVO + WD Caviar Black | Fractal Define R3 | Phanteks/Noctua/NoiseBlocker cooling | Windows 10 Pro
MacBook Pro (13-inch Mid 2010)
Intel Core 2 Duo P8600 | Apple Mac-F222BEC8 | 2x4GB Samsung PC3-8500 | GeForce 320M
SanDisk SDSSDP | Apple A1278 Aluminium Unibody | macOS Sierra
Microsoft Lumia 950
Qualcomm Snapdragon 808 | 3GB RAM | Adreno 418 | Windows 10 Mobile
daily driver 2
Intel Core i5-750 | ASUS P7P55-M | 4x1GB Elpida PC3-8500 | Sapphire Radeon HD5870 | SB X-Fi Xtreme Music
Crucial M4 + WD AV-GP Green | Fractal Define R3 | Scythe/Gelid/Noctua/NoiseBlocker cooling | Windows 10 Pro
MacBook Pro (15-inch, Mid 2012)
Intel Core i7-3615QM | Apple Mac-4B7AC7E434945597E | 2x4GB Samsung PC3-12800 | GeForce GT650M
WD Blue | Apple A1286 Aluminium Unibody | macOS Sierra
server
AMD Athlon 64 LE-1620 | Jetway JNC62K | 2GB Corsair Value Select PC2-6400 | GeForce 8200 IGP
WD Caviar SE16 + AV-GP Green + 2x Red | Chenbro ES34069 | Scythe/Nexus/Noctua cooling | Windows Home Server
coming soon: Eve V
Intel Core i7-7Y75 | Skybay U3E1 | 2x8GB Samsung PC3LP-14900 | Intel HD 615
Intel 600P | Eve V Aluminium Unibody | Windows 10 Pro
try restarting your pc, if that doesn't work then reinstall the drivers for it. something simular happend before with my 970 so if basicly throttled because the fan wasn't turning on. for me a restart worked
Main build
CPU: i7 5820k  MotherBoard: Gigabyte x99 UD4  RAM: corsair ballistix 2400mhz 4x4gb  GPU: Asus GTX 970  PSU: corsair rm1000  SSD 1: Samsung 840evo 500gb  SSD 2: Samsung 850evo 500gb  HDD: Western Digital red 3tb  Case: Phanteks Enthoo pro M  CPU cooler: corsair h80i
Second build
CPU: i7 5820k  MotherBoard: Gigabyte x99 UD5 WIFI  RAM: G.skill 2666mhz 4x4gb  GPU: Nvidia GTS 450 (soon to be upgraded)  PSU: corsair HX650  SSD: Samsung 850evo 250gb  Case: Cooler Master 430 elite  CPU cooler: Cooler Master hyper 212 evo
Third build
CPU: xeon x5690  MotherBoard: Evga x58 classified 4way-sli  Ram: Patriot 1600mhz 4x3gb  GPU: Asus HD6970  PSU: fractal newton r2 1000w  SSD: crucial m500 240gb  Case: Cooler Master Haf X  CPU cooler: Mega Shadow
