I'm looking to buy an m.2 ssd for my MSI Ge 62 Apache pro to have it as my OS drive, it has 3 open m.2 slots and I want to use them instead of having to re-purpose my dvd drive just in case.
I'm looking at these: Adata SP900  http://www.ncix.com/detail/adata-sp900-256gb-m-2-2280-ed-98601-1928.htm
Samsung 850 EVO http://www.ncix.com/detail/samsung-850-evo-250gb-m-2-10-110825-1786.htm
SanDisk X400 http://www.ncix.com/detail/sandisk-x400-256gb-m-2-2280-f6-125367-1307.htm
Do they have controllers inside them just like their 2.5 form factors? Which would be better for general use? Is it easier to get a replacement if something goes wrong.
https://linustechtips.com/topic/558391-differences-between-m2-ssds/
M.2 SSDs do have controller chips, and really, any other component that you might find inside their 2.5" counterparts. It's just the form factor, connector and PCB layout that are different. Performance-wise, there should be no noticable difference between a Samsung 850 EVO 2.5" SATA model, its mSATA variant or its M.2 variant. The prices will generally be similar, though the 2.5" model may be easier to shop for as more stores will carry them.
M.2 SSDs come in both SATA and PCIe flavours. The SSDs will be of one type or the other, but mainboards (or laptops, as is the case here) may support only SATA drives, only PCIe drives, or both. From what I can tell, your laptop supports up to three SATA/6G SSDs, or one PCIe SSD and up to two SATA/6G SSDs. Something to keep in mind for performance and future expansion. PCIe SSDs will support higher speeds than SATA ones, even though the physical connector is the same.
A Samsung 950 Pro may be an interesting option, if the MSi GE62 Apache Pro supports NVMe (I couldn't find this specification in the manual). Being a PCIe model, it's capable of much higher data throughput than the SATA models.
daily driver
Intel Core i7-950 | ASUS SABERTOOTH X58 | 6x2GB Corsair XMS3 PC3-12800 | ASUS GTX970 STRIX | SB X-Fi Titanium
Samsung 840 EVO + WD Caviar Black | Fractal Define R3 | Phanteks/Noctua/NoiseBlocker cooling | Windows 10 Pro
MacBook Pro (13-inch Mid 2010)
Intel Core 2 Duo P8600 | Apple Mac-F222BEC8 | 2x4GB Samsung PC3-8500 | GeForce 320M
SanDisk SDSSDP | Apple A1278 Aluminium Unibody | macOS Sierra
Microsoft Lumia 950
Qualcomm Snapdragon 808 | 3GB RAM | Adreno 418 | Windows 10 Mobile
daily driver 2
Intel Core i5-750 | ASUS P7P55-M | 4x1GB Elpida PC3-8500 | Sapphire Radeon HD5870 | SB X-Fi Xtreme Music
Crucial M4 + WD AV-GP Green | Fractal Define R3 | Scythe/Gelid/Noctua/NoiseBlocker cooling | Windows 10 Pro
MacBook Pro (15-inch, Mid 2012)
Intel Core i7-3615QM | Apple Mac-4B7AC7E434945597E | 2x4GB Samsung PC3-12800 | GeForce GT650M
WD Blue | Apple A1286 Aluminium Unibody | macOS Sierra
server
AMD Athlon 64 LE-1620 | Jetway JNC62K | 2GB Corsair Value Select PC2-6400 | GeForce 8200 IGP
WD Caviar SE16 + AV-GP Green + 2x Red | Chenbro ES34069 | Scythe/Nexus/Noctua cooling | Windows Home Server
coming soon: Eve V
Intel Core i7-7Y75 | Skybay U3E1 | 2x8GB Samsung PC3LP-14900 | Intel HD 615
Intel 600P | Eve V Aluminium Unibody | Windows 10 Pro
